TSP True Duals
Old Feb 19, 2005 | 01:17 PM
WALLY99'SS's Avatar
Default TSP True Duals
I just recieved my TSP tue duals on Thursday and last night I started putting them together. All the pipes are labeled R-1, L-1, L-2, but I can determine which side of the x pipe is the top facing the bottom of your car and which is the bottom facing towards the ground. The x pipe is not label with R-2 and L-3. Can anyone help me out. Also did anyone just use the clamps that went with the kit to bolt on or did some of you weld it all together.
Old Feb 19, 2005 | 02:39 PM
01TAFlyer's Avatar
There is a top and bottom to it, it has some angle in it. To get mine to tuck up correctly, I put it together to where it angled up, toward the bottom of the car. Otherwise you bullets will hang down low.
Old Feb 19, 2005 | 06:02 PM
DOUBT IT's Avatar
If it helps any, the forward part of the X will be straight, then curve down to a point, then will curve sharply up and be higher towards the rear.
You could just do what I did to be sure, assemble the system on the ground. The back part of the X should tuck the mufflers up farther when you have it right side up. So pretty much whichever way tucks the mufflers up the farthest.
Don't have any pics, but I hope this helps...
Old Feb 19, 2005 | 09:31 PM
ZR2877's Avatar
I got some 3" strap clamps from Napa for mine they seem to work pretty good. I think TSP only send 2. It is a great system you will be happy with it.
Old Feb 19, 2005 | 09:35 PM
WALLY99'SS's Avatar
Default Thanks
Thanks guys. One other thiung did you guys bang the pipes together with a hammerso they would fit snug on there or did you ust slide them on and clamp them down.
Old Feb 20, 2005 | 04:09 PM
01TAFlyer's Avatar
I just slid them on, and then clamped them.
Old Feb 21, 2005 | 01:03 AM
kotcls1's Avatar
I actually had my buddy who owns a muffler shop heat up the pipe to ensure a great fit. I guess I'm lucky to have had his help, it came out perfect.
