FAST 90 and cam sensor problem
Old Feb 21, 2005 | 09:17 PM
Beast96Z's Avatar
Default FAST 90 and cam sensor problem
I finally got the new motor in the car and when I went to plug in the clip for the cam sensor, the FAST intake was sitting on top of it. Obviouslly the sensor won't plug in cause the intake is in the way. I don't "think" the intake is touching the sensor, but it is so close that it won't allow me to plug it in. Anyone else had this problem? I could break of the clip that holds the plug in place, but I'm not to wild about doing that.
Old Feb 22, 2005 | 03:27 AM
smokin' joe 00 ss's Avatar
If I'm reading this right your talking about the clip for the sensor's under the intake and you are suppose to un tape the clip and remove it from the harness.
Old Feb 22, 2005 | 10:13 PM
Beast96Z's Avatar
I'm talking about the CAM sensor. The one next to the oil pressure sensor. The rear of the intake is sitting so close to it that it won't allow the harness side to plug in. I removed the intake today to try and figure it out.
Old Feb 23, 2005 | 12:27 AM
Beast96Z's Avatar
FWIW, the intake went back on fine once the sensor was plugged in. I guess it has to be plugged in with the intake off, cause it wasn't going to go with it on.
Old Feb 23, 2005 | 03:18 AM
Ok I know what your talking about now, I did not have this problem when I installed mine it was tight but it could be plugged in after the intake was sitting there.
