Post header install blues...lend me your brains!
Thanks
Seriously though, I had the Kooks ORY and I couldn't get rid of the banging if my life depended on it. I just replaced the whole setup with TSP true duals and now I have no banging at all.
Solid trans mount won't solve anything. You'll need solid motor mounts to HELP out. You see, a torque is applied at the motor mounts every time you go WOT and it pulls the y-pipe up against the floor board. The solid motor mount will absorb the torque on the motor and your banging will be reduced/go away.
The only problem with solid motor mounts is: If you think you have rattles now, just wait till your teeth chatter with solid mounts.
Some people have had limited success with the mufflex y-pipe hanger also. Do a search for that.
One guy on here also welded an old comp valve spring between the y-pipe and the floor board and that cured his banging.
Good luck
Good luck
Solid mounts-for racing, not the street. It puts more stress in the frame and body. In the chevelle, I broke a TH350 trans almost in half, and the frame is cracking.
And the valve spring- I was told by Tyson of Performance Auto Fabrication, that that is not a good fix. He says the heat going into the spring will make the spring brittle and break.
I would go with a hanger, that looks like this ( Check attachment)
