Help, running horrible
Old Mar 5, 2005 | 08:29 AM
Bad30th's Avatar
Resetting it only resets the "learned" values that change constantly. It doesn't change the "tune".
Reflashing entails reprogramming the entire VCM with a new "tune", either stock or customized.
If the car is completely back to stock it couldn't hurt to have the dealer update/reflash it, but I'm guessing that's not where the problem is.
Check for cracked plugs or unsecured spark plug wires already ? Maybe one got the insulation cracked with the socket during the plug swap when you put the factory exhaust back on ? Just fishing for ideas...
Have you scanned it with a scan tool ? How do the fuel trims look ? A high fuel trim can indicate a vac leak.
Good luck,
Bad30th
Old Mar 8, 2005 | 07:06 PM
Bryan 02TA's Avatar
Well my diablo predator has a "real time data" feature. I have no idea what i'm looking for though. It shows spark, o2 sensor stuff, temps, rpms, mph, and a bunch of other terms i have no idea about. If anybody is familiar with that and can tell me what to look for, lemme know. Otherwise i guess i'm gonna have to pay for a high tech diagnostic machine to check it out
Old Mar 8, 2005 | 08:57 PM
4.6gt-2-ls1ta's Avatar
do you have a custom tune on your predator for the headers or are you useing just the performance tune the predator came with? I would try to see if uploading the stock tune back in the car makes any difference.
Old Mar 8, 2005 | 09:32 PM
Bryan 02TA's Avatar
i am running the stock tune now. I had a performance tune for the cam and boltons, now it is just bone stock.
Old Mar 9, 2005 | 12:05 AM
FIREHAWK #07's Avatar
mine used to do similar thing.... no power, backfiring, popping,..... this has happened twice to me...... One time it was a front o2 sensor, the other time, i changed my opti (distributor) wires, and it wasnt it..... turned out to be a hair line crack on one of my NGK plugs.... I spent like 250 dollars, and it turned out to be a $2.50 plug
Old Mar 9, 2005 | 05:58 AM
Bryan 02TA's Avatar
i think i'm going to replace all the plugs today or tomorrow.
Old Mar 9, 2005 | 08:18 PM
Bryan 02TA's Avatar
took the plugs out and sure enough, i THINK i found the problem!!
Old Mar 10, 2005 | 08:48 AM
Bad30th's Avatar
Bad30th
Old Mar 10, 2005 | 07:56 PM
Monello's Avatar
I bet your car is fine, just that you have no Y- Pipe, which is causing the problem. The O2s arent heating up enough so they are making your car misfire.
Put a y pipe on there, and i bet it will make everything run smooth.
