Headers or no headers
Old Mar 4, 2005 | 09:00 AM
Camaro Dreams's Avatar
Question Headers or no headers
I'm wanting to put the SLP Long Tuned Headers on my car, but there is talk about emission test starting up, and it wouldn't be worth it to put them on if it would make me fail the test and have to pull them off. I have the FloPac system, Loudmouth exhaust, Y-pipe, and mass air sensor already, the headers would be the icing on the cake for me. Do any of you have this stuff already and have to go thru the emission test??? I would run the high flow catalytic converters with them if I able to pass
Old Mar 4, 2005 | 11:45 AM
jrp's Avatar
jrp
SN95 Director
slp fan are we
if its only OBD2 all you have to do is make sure theres no DTC's, turn off the rear o2's or run o2 sims.
and get kooks.
Old Mar 4, 2005 | 09:37 PM
elite22xl's Avatar
i just ordered qtp's headers, go with them or kooks, both great headers, heard too many bad things about SLP headers
Old Mar 4, 2005 | 09:44 PM
ddelallata's Avatar
Yup, try to stay away from the SLP headers.
Old Mar 4, 2005 | 09:49 PM
DravenMyers's Avatar
My car should pass no problem in cali with all my mods thats because it wont have to thier to smog it. I got the hook up smog
Old Mar 5, 2005 | 01:31 AM
Schantin's Avatar
Whether to run LT headers vs emissions will be based on the actual emmission laws. All the LT header/ cat y-pipe combos do say they're for "off-road" use only. This is due to changing the location of the converters from the stock location. This is because the cat converteres are "supposed" to be in the stock location in many states, which is impossible for LT's. However, most places only check to be sure there actually ARE converters installed, and that the car isn't throwing SES codes. (Like in my parent's home state of Maryland or where I live in Hawaii.) So, unless the emissions are run by true *** clowns, it shouldn't be a factor.
I'd stay away from the SLP headers. They hang low and I've heard of some people complaining of install issues as well. Kooks makes LT's with converter Y-pipes. They use Magnaflow cats. QTP also has a cat converter y-pipe for their system. They are both good, but on the upper end of cost. I will be running Dynatech Supermaxx headers with integrated cats and y-pipe. All the above brands are stainless steel. I got the Dynatech ones on a GP for cheap, which is why I went that route. (I can't tell you much else about them, because they're still sitting in my dining room.)
Hope this helps.
Schantin
2002 Camaro Z28 M6
Old Mar 5, 2005 | 02:48 AM
MTz8's Avatar
they do emmisions tests in tennese? didnt know that
Old Mar 5, 2005 | 08:52 AM
ruck98's Avatar
i live in commerce georgia there no testing up here yet but if there is i just go to another county and get my tag no big deal theres no way in hell im putting cats! on my car
 Michael S. Palmer
Old Mar 5, 2005 | 11:52 AM
SScreaminDemon's Avatar
Im not running any cats and I passed in Marietta, GA this past Thurs.
Old Mar 5, 2005 | 12:21 PM
Durien's Avatar
QTP stainless is the way to go
Old Mar 5, 2005 | 04:01 PM
02WS6Bird's Avatar
go QTP LT's
Chances are if they DO start emissions itll be the OBDII scan for codes- just do it and keep your stock manifolds-if they start the sniffer test or anything other then the OBDII then just b4 you take it to get tested-take off the LT's and put on your stock manifolds these cars NEED the LT's
Old Mar 5, 2005 | 04:38 PM
Hot02SS's Avatar
I was thinking about putting on the SLP's. Heard to many bad things about them, thinking about going with QTP's now.
Old Mar 7, 2005 | 07:17 PM
kpowr82's Avatar
Don't buy anything SLP. Overpriced and customer service is terrible, especially regarding warranty issues.
Kook's headers are the way to go IMO. QTP/Kooks are the same design.
Old Mar 7, 2005 | 09:57 PM
blkZ28spt's Avatar
Old Mar 7, 2005 | 10:02 PM
lilstephsls1's Avatar
CT Hotness
from what i heard by everyone, slp headers are junk. i love my kooks, and if you had intentions of purchasing the pricey slp headers then you can afford the kooks
