Battery Relocation Question
Old Mar 8, 2005 | 05:01 PM
Blackbird's Avatar
Default Battery Relocation Question
Do I need to put a fuse or breaker on the power wire?
Seems like a good idea for saftey but the breaker/fuse would have to be HUGE to avoid popping every time I start the car.
Let me know guys.
Thanks!
Old Mar 8, 2005 | 05:13 PM
ApacheDrill's Avatar
Your best bet is use the Taylor relocation kit. The gauge is high enough on the cable that you wont have any problems or need a fuse..
Old Mar 8, 2005 | 05:16 PM
Blackbird's Avatar
I have already wired everything up with a Summit Kit.
Just wondering if I needed to add a breaker or fuse.
Research is suggesting just add a cut-off switch and make sure you route everything so you dont cut thru the wire and you should be good.
Old Mar 8, 2005 | 11:17 PM
felton316's Avatar
What size power wire did you install with that kit? I've been planning on doing the same some time soon. The stock setup didnt have a fuse, so I don't see why you would need one now.
