electric valve for borla questions
Old Mar 10, 2005 | 09:55 AM
delusion's Avatar
Default electric valve for borla questions
1. is DMH better then QTP in terms of reliability?
2. is there a standard size i can get the valve in or does it have to be custom made to fit the borla flange?
3. What kind of switch does the cut out use? is it a momentary ON/OFF/ON?
thanks.
Old Mar 11, 2005 | 09:56 AM
John_D.'s Avatar
I had a dmh.
It came with a momentary on/off/on rocker switch.
The borla flange is different than a standard flange.
You can compare one of your plates to a standard header collector gasket to see the difference.
