Major problem!!!
Old Mar 14, 2005 | 12:48 AM
deznuttzz28's Avatar
Default Major problem!!!
has anyone of you guys messed up the thread on the block where the spark plug goes???
i just found out couple of days ago that the specific one is messed up. what are my option to get this fix???? thanks for the help
Old Mar 14, 2005 | 01:23 AM
NviouSS's Avatar
you could go to an auto store and get a tap to rethread it.
Old Mar 14, 2005 | 08:00 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
If the tap doesn't work you will probably have to drill and tap for a helicoil.
Old Mar 14, 2005 | 10:35 AM
98Z-6Speed's Avatar
On a related note, does the #1 plug sit farther out than the rest? The number one plug on my LS1 does not seat as far into the head as the rest of the plugs. The nut on the plug does not go all the way into the recess on the head, while all the other plugs' nuts go completely down into their recess. Anyone else ever notice this, or is my #1 spot messed up? The plug tightens down nice and tight, it just does not go as far in as the rest of the plugs.
I hope that was clear.
Old Mar 14, 2005 | 12:15 PM
HAMRHEAD's Avatar
Just go get a tap and rethread it. That should work unless it is really messed up!
Old Mar 14, 2005 | 01:47 PM
99trickin's Avatar
make sure to grease the tap as to capture the metal that may come off the threads,or the may go into the cylinder and cause valve damage.
Old Mar 16, 2005 | 06:41 PM
thanks for all the help guys.... my car is currently at the shop to get re-tapped
Old Mar 16, 2005 | 08:59 PM
ddelallata's Avatar
I hope that everything comes out OK. Messing up the threads or breaking a bolt is one of my biggest fears everytime I work on my LS1.
 Michael S. Palmer
