engine and MAF cleaning
Old Mar 18, 2005 | 04:04 PM
jimmy 2 Times's Avatar
Default engine and MAF cleaning
i want to use the GM top engine cleaner. I want to use the aresol stuff, because the liquid seems to be too messy. What is the best way to do it?
also, why I am at it, I am going to clean the MAF. How exactly do you clean that with, and how do you do it?
Thanks
Old Mar 18, 2005 | 04:53 PM
ddelallata's Avatar
you can clean the MAF with alcohol impregnated cotton swabs (carefully)
Old Mar 18, 2005 | 04:55 PM
LSUxBlake's Avatar
Autozone sells Electric Parts Cleaner for the MAF, and you dont have to use any contact on the fragile wires. Just spray it on it, and you can see the dirt dripping off.
Old Mar 18, 2005 | 05:32 PM
yes, i have some of that that stuff, i just wanted to make sure that that was the stuff to use.
Does anyone know about the Top engine cleaner??
Old Mar 18, 2005 | 05:55 PM
jay_99z's Avatar
This is with the regular bottle.
I pull off the PCV and hook up a line to the intake. (other end to top end cleaner)
Set the idle to about1K.
Take in half the bottle and let it sit for 15-20 minutes.
Let it suck up the rest.
Drive it until it quits smoking and change the oil.
I've seen a couple different methods used. This seemed to work fine. Smokes like hell and smells great for a while.
Old Mar 18, 2005 | 05:59 PM
ddelallata's Avatar
how much is the GM top end cleaner?
Old Mar 18, 2005 | 06:01 PM
jay_99z's Avatar
$5 from a dealership
