Borla Help!!!
Old Mar 19, 2005 | 08:29 PM
99M6Z28's Avatar
Default Borla Help!!!
I am wanting to change out the block off plates on my Borla but I am finding it very hard to get to the top bolt. What do you use to get the top bolt loose? There just isn't enough room under there. HELP PLEASE!!!!!!!
Old Mar 19, 2005 | 08:51 PM
Phoenix 5.7's Avatar
ive had the same problem too. once you get it off, put some antiseize on it. busted knuckles is the only way i know to get it off
Old Mar 19, 2005 | 08:53 PM
99M6Z28's Avatar
I just can't seem to get on the bolt good enough to get it off.
Old Mar 19, 2005 | 09:04 PM
i was able to get a ractchet on it with a 3in extensoin. had no leverage though. i only adjusted it once though, to WIDE open
Old Mar 19, 2005 | 09:05 PM
99M6Z28's Avatar
Thas what I want Wide open!!
Old Mar 19, 2005 | 09:07 PM
defanetly put antiseize on once you get it off. andy you don't need the washers or nuts. I don't use them and my tip is really tight
Old Mar 19, 2005 | 10:47 PM
ddelallata's Avatar
I always use a Craftsman wrench with no problems.
Old Mar 20, 2005 | 09:23 AM
99M6Z28's Avatar
ok I will have to try again
 Michael S. Palmer
John_D.'s Avatar
I just used a long extension. There wasn't enough room up there for the ratchet, but a 12" extension worked fine.
Old Mar 20, 2005 | 10:21 AM
LSUxBlake's Avatar
Yep, I probably did mine 15 times when I had my borla. 12" extension hits it perfect every time.
Old Mar 20, 2005 | 07:10 PM
99M6Z28's Avatar
I was able to get the job done. I got the 3 nuts off easy but had to use an impact on the studs. Thanks
