Help...Plug Wire Question
Old Mar 23, 2005 | 04:09 PM
2000Z28M6's Avatar
Default Help...Plug Wire Question
I'm in the middle of installing some Hookers and when I pulled out the taylor 8mm plug wires one of them left the metal clip on the spark plug, I carefully pulled it out with a screwdriver and fitted it back in place how its suppose to go. My question is it ruined, do I need a new one? Or should I be ok with what I did ? Has anyone else had this happen to them?
Old Mar 23, 2005 | 04:12 PM
ddelallata's Avatar
it should be fine for the time being if you put it back the way you said you did.
Old Mar 23, 2005 | 04:14 PM
Sudz's Avatar
Man I posted in a post about the taylors along time ago, their notorius for this!
Old Mar 23, 2005 | 04:32 PM
2000Z28M6's Avatar
so it will be ok then? I need to know for sure because I still got the stockers if its not worth it.
Old Mar 23, 2005 | 05:51 PM
ddelallata's Avatar
it should be OK.. if you notice a miss just put a stocker in its place while you get a new set. The stock wires are so short and efficiente that its OK to run seven Taylors and one stock wire.
