SLP Lid Question
Old Mar 25, 2005 | 10:24 AM
Martingale's Avatar
I'm on my second SLP lid (different car) and I bought this one because the last one fit great. I have a K&N and the gasket fits fine with the lid. No hood rub at all. Also, the SLP kid has the provision for the AIR tube on '00+ cars.
Old Mar 25, 2005 | 10:50 AM
NateLS1's Avatar
I also have the SLP lid. Usually it doesn't fit because of USER ERROR. The front lip tucks in, that's where I got confused. If installed correctly it fits perfectly and it is very sturdy.
Old Mar 25, 2005 | 08:37 PM
67SS&99SS's Avatar
I too have an slp lid and it fits great. If the front lip isn't tucked it it will not fit correctly. I have never had a hood rubbing issue. I also have the slp smooth bellow and it is a quality piece.
Old Mar 25, 2005 | 09:49 PM
Andros's Avatar
SLP Lid running great here
Old Apr 8, 2005 | 12:51 PM
mattjigga00's Avatar
Overall, which would be the best bang for the buck along with quality, SLP or MTI lid? I am considering buying one very soon. Also, are they easy to install??
Old Apr 8, 2005 | 01:00 PM
Tranzor's Avatar
Lids are all basically the same... I'd just pick whichever one is most cost-effective for you.
And yes, very easy to install... about on par with installing a game in your X-Box.
Old Apr 8, 2005 | 03:47 PM
Mr Incredible's Avatar
I have a question...
Has anyone ever removed the ribs on the inside of the stock lid and done a flow/dyno test? Does anyone think it did any good?
Old Apr 8, 2005 | 04:12 PM
DOUBT IT's Avatar
Running the SLP lid here with no problems. I didn't put a new gasket for the K&N on the lid and it seals fine. When you press up on the filter from underneath (FRA), it doesn't move at all.
Old Apr 8, 2005 | 04:41 PM
Another_User's Avatar
I took mine to the GM dealership for an oil change one time, and they "checked" my air filter (even though I had a K&N sticker there), and those retards could not even put my lid back on right. All the tabs in BACK were out. What a bunch of idiots. Another reason why I don't trust mechanics.
Old Apr 8, 2005 | 07:24 PM
RomanK's Avatar
I bought a SLP lid two weeks ago for my '01, fits great, no it did not come with any special seal, i do have a K&N also, in GMHTP test the SLP lid performed as well as MTI did on the drag strip test, but SLP did MUCH better on the dyno, read the test again
Old Apr 8, 2005 | 09:16 PM
Bones SS's Avatar
SLP lid here, no problems
Old Apr 8, 2005 | 09:29 PM
  #32
psykoTA's Avatar
SLP lid, no issues whatsoever. Fits great. Only thing I had to do was call K&N, and they sent me another seal, the first seal was on the stock lid.
About removing the fins from the stock lid, you still have the huge air chambers after the lid.
Old Apr 9, 2005 | 10:40 AM
  #33
SStheBest's Avatar
SLP lid and BELLOW here....although i must say i DO have a problem w/ my lid hitting my hood ....BUT i have a clear patch on the hood so it doesnt get scratched
Old Apr 9, 2005 | 06:17 PM
  #34
tboysen00's Avatar
have a slp lid, fits like ****, rubs the hood, latches or whatever fall of imediatley. POS
Old Apr 9, 2005 | 06:21 PM
  #35
BrandonSS's Avatar
Maybe you should install it correctly. The lip needs to be tucked.
Old Apr 9, 2005 | 06:36 PM
  #36
SmaknaSS's Avatar
Originally Posted by Another_User
WTF are you guys all talking about? My lid has never rubbed the hood. And it is actually made out of the best quality plastic of all the lids, the same stuff the OEM lids are made out of (whatever that is), which cracks far less than other types of lids. Just my .02.
I love my SLP lid, I once had a problem with the lid rubbing once due to the hood Height was not ajusted properly. Reajusted it, nows all fine.
Old Apr 9, 2005 | 10:54 PM
  #37
Deamon2002's Avatar
Personally I think my SLP lid fits great, you can see it on my site below. I knnow SLP has some porr products, but IMO the lid is not one of them. This thing is pretty stout from what I can tell.
Old Apr 10, 2005 | 12:00 AM
  #38
ferariguy3's Avatar
Originally Posted by SLP LS1
Question is why are you buying an SLP lid? They rub the hood(damaging paint) and they don't fit good at all!!!
Mine fits great, and its on a Firehawk, also got 18HP on a STOCK engine...dyno proven...i can't see how you can beat that
Old Apr 10, 2005 | 01:15 AM
  #39
BackinBlack02SS's Avatar
Is the "aftermarket" SLP lid the same exact lid that came on the 345 hp optioned cars?
Old Apr 10, 2005 | 07:39 AM
  #40
No, that lid is a Blackwing lid. If it were not so friggin expensive, I would have bought one for testing. It appears to flow just about the same as the aftermarket one, but there are a few differences.
1) It appears to be just as sturdy as the stock lid, which is nice.
2) The hole going towards the MAF is shaped like an oval, just like the regular stock lid. I am quite positive this is per GMs requirement that the lid was to work properly with the stock MAF (not throw all the trims off like the aftermarket lid). I would recommend the Blackwing lid over a regular SLP lid if you are worried about fueling issues. I think it would be easier to tune too.
