LS6 Intake install questions..
My question deals with a rubber hose that comes out of the passenger side valve cover and splits into a y. One side runs into the intake just behind the TB on the passenger side and the other end runs around the back of the manifold and I think it used to plug into the valve that was related to the emissions. I need to know if this is the proper routing and do I need to keep this hose or can I plug the inlet on the manifold and the outlet from the valve cover?
Can I at least elimate the part that runs behind the manifold since if I'm correct I've been running without it since I did the headers anyways?
Thanks.
http://www.ls1howto.com/index.php?article=18
