Clean or replace valve cover breathers?
Old Apr 8, 2005 | 12:20 PM
MeanWS6's Avatar
Default Clean or replace valve cover breathers?
Do you clean or replace them and how often?
If cleaning them, what do you use?
Old Apr 8, 2005 | 07:11 PM
Cstick's Avatar
I got rid of them last weekend and went back to PCV. When I was using them I replaced them. I was using a Mr. Gasket valve cover breather, no way to really clean the foam filter inside.
Old Apr 8, 2005 | 07:22 PM
SBChevrolet's Avatar
you can try foam or K&N type air filter cleaner... but u can get those little filters pretty cheap $5-10
Old Apr 8, 2005 | 07:36 PM
MeanWS6's Avatar
where do we get the filters?
Old Apr 8, 2005 | 11:15 PM
santino04's Avatar
Are you using the closed breathers, or an open element one like K&N. If you have the open element one just use some soapy water and running water. A dishwater soap works well to carry away the oil and then rinse it good and let it dry. The closed or sealed ones I dont believe you can clean, unless its one those two piece designs that allow you to unscrew the top for removal and cleaning of the filter element and for oil fills. Good Luck
Old Apr 9, 2005 | 03:23 PM
SmaknaSS's Avatar
Not to hijack the thread but why did you go back to the PCV?
Old Apr 9, 2005 | 08:03 PM
Cstick's Avatar
The first 3,000 miles they were fine, but this last 3K during the winter I would have to scoop out all kinds of sludge crap that built up in the oil fill neck. I went through 3 valve cover breathers trying to keep it clean. Don't know if moist conditions worsened this but, what ever it was smelled like fuel bad and I know some of it had to have dripped back into the engine so I said the heck with it, I am going to buy a catch can. I have a filter inline right now.
