Coil Relocation Help
Old Apr 10, 2005 | 03:02 PM
MstgKillr's Avatar
Default Coil Relocation Help
I am trying to install the Thunder Racing coil relocation kit. I need some pictures or some help on where the brackets actually mount to the cowl. I don't want to start drilling holes and screw something up. Thanks in advance for any help.
Old Apr 10, 2005 | 03:34 PM
LawmanSS's Avatar
Damn...I forgot to take pictures of mine before I reinstalled the cowl.
The passenger side goes on the sheet metal cross brace. The driver's side goes near the cutout, where the opening begins to curve upwards. You need to "eyeball" the location of the bracket such that there is enough sheet metal under the bracket to drill the holes...attached, there is a pic that I marked with arrows...you can also refer to Thunder's site to get a feel for where the packs should end up...hope this helps.
Old Apr 10, 2005 | 07:57 PM
nikon1999's Avatar
i had the same question when i did mine, but if you put them in there with the coil packs on theres really only one way they'll fit on well.
