SShorty headers
Old Apr 11, 2005 | 08:26 PM
Dipstick's Avatar
Default SShorty headers
I have a 2000 LS1 powered sandrail with stock manfolds from a 1999. They cleaned up better than the 2000 cast iron manifolds.
I am not running any converters. I cut off and welded up the emission tubes. I want some shorty headers that will bolt right up to my short tailpipe and mufflers.
Is the tailpipe/converter flange different with 2000 stock and shorties? Mine has a three bolt flange on both left and right sides. I want this to be a bolt on mod.
I saw on the speed channel that they gained 15HP with the shorties on a 98,
Old Apr 11, 2005 | 10:39 PM
WILWAXU's Avatar
Yup. 2000 & up stuff is different than the 98-99 ones.
By the way.. don't believe everything you see on TV
IMO a good set of 2000 up cast iron manifolds flow about as good as aftermarket shorties.
Old Apr 22, 2005 | 02:06 PM
lsx24's Avatar
Possibly, however I have never seen any 02s or 01s dyno higher than 320-325 without headers. Check my sig.
Old Apr 22, 2005 | 02:12 PM
Coy's Avatar
Coy
shorties will give you little to no gains. Look for a set of 01-02 manifolds, or a set ov vette manifolds. If you are going to get shorties, Get JBA.
Coy's Avatar
Coy
shorties will give you little to no gains. Look for a set of 01-02 manifolds, or a set of vette manifolds. If you are going to get shorties, Get JBA.
Old Apr 22, 2005 | 02:23 PM
CaptUSA's Avatar
LS1 powered sand rail....
Old Apr 22, 2005 | 08:31 PM
Black Z/28's Avatar
With ported stockers, RT/y, lid, and Magnaflow muffler my '02 dynoed 337.
