throttle stop
Old Apr 12, 2005 | 06:11 PM
tboysen00's Avatar
Default throttle stop
Im going to modify my throttle stop to 100% wot. It says you can back probe the throttle position sensor and monitor the voltage to 4.6. HOW DO I BACK PRBOE THE THROTTLE SENSOR. thanks Troy
Old Apr 15, 2005 | 10:43 PM
WILWAXU's Avatar
Install University has a good write up on doing that:
http://www.installuniversity.com/ins..._bump_stop.htm
Old Apr 17, 2005 | 02:23 PM
tboysen00's Avatar
thanks allot that helps
Old Apr 17, 2005 | 06:16 PM
soundengineer's Avatar
you can go all the way to 4.69 ohms....(4.7 and you set a code)
just use a multimeter(preferrably digital) make sure you calibrate it to 0 first....
and you can touch 2 of the pins on the sensor to get your reading... I dont have mine off to tell you which pins.... its easy to figure out... just try them until you get a reading
you have to hold open the tb at the same time to get the reading...can be tricky if you do it yourself with only 2 hands...but I did it on my own...
Old Apr 17, 2005 | 07:32 PM
slow's Avatar
do you look for 4.69 ohms, or 4.69 volts?
Ryan
