Crank Pulley Questions
My/his questions are as follows:
1.) Should the pulley be the same size?
2.) What are the negative effects of putting on a lighter/different size pulley?
3.) What are some popular brands?
4.) What size belt will be needed as well?
5.) Does anything else have to be changed out?
6.) With some imports (what i'm familiar with since I own one - 1G Eclipse) its common to get an aftermarket fuel management system when performing a mod such as bigger injectors. I know its not the same subject but I think you get my point. Will he have to do something like this?
378K4 Belt for AC Pulley
760K6 Accessory Belt for ASP Crank Pulley Only
770K6 Accessory Belt for ASP Crank & ASP Underdrive Alternator Pulleys
755K6 Accessory Belt for ASP Crank & ASP Overdrive Alternator Pulleys
