juice
your plugs are absotively not ok to run with nitrous...get a set of NGK TR-6's and gap em between 35 and 40...if you're not running a window switch you better make sure you don't activate the system lower than 3000 rpms at WOT...otherwise all those nitrous myths that you hear about will come true...with a WOT switch, window switch, & FPSS, you shouldn't run into any problems running nitrous but, yes it's a good dea to run a step colder and smaller gap. on a 75 shot though, i don't see a need for it.
don't listen to me though, i'm dangerous.
