crank pulley problem
Old Apr 26, 2005 | 08:20 PM
rollinna65's Avatar
Default crank pulley problem
hopefully this is the last post of my cam swap. i was putting everything back together tonight and when i got to the crank pulley i ran into a little trouble. with the pulley on the crank i can't get the bolt to grab any threads in the crank. i am using the FMS crank bolt from their gasket kit. is this the 1" longer bolt or do i need a different one? if so, can i get the bolt at any major auto parts stores? thanks for your help guys, hopefully the car will be up and running tomorrow.
Old Apr 26, 2005 | 08:31 PM
White.Lightning's Avatar
Try reversing the pulley puller to presss the pulley on enough to have the threads catch on the bolt. This happened on a buddies Mustang. Hope this helps
Andy
