1 7/8" headers on a 346?
Old Apr 27, 2005 | 09:53 AM
BAIN's Avatar
Default 1 7/8" headers on a 346?
Since the search function isn't working Are there any gains going to 1 7/8" Kooks race headers on a stock block 346 with a big cam (T-Rex) and stock heads over say Hooker LT's?
Old Apr 27, 2005 | 10:00 AM
DAPSUPRSLO's Avatar
Look at some of David Vizards exhaust articles. It comes down to the flow of the exhaust ports of the heads. He has a chart in popular hotrodding that gives you a good idea of the optimal primary diameter for a given peak exhaust flow. In general the better exhaust flow of the head the larger primary size you want.
Old Apr 28, 2005 | 01:05 AM
WILWAXU's Avatar
I've ran a 1 7/8's mid-length header on my car for years. In a high reving A4 setup, I don't see any disadvantages. But, not sure I would pull a set of good 1 3/4's off to run 1 7/8's.
Old Apr 28, 2005 | 11:22 AM
BAIN's Avatar
Just trying to get every little bit of hp and tq out of it can
Thinking of going with a 90mm intake and tb also. There just isn't much information on how they do on a cam only 346
Old Apr 28, 2005 | 12:48 PM
jrp's Avatar
jrp
SN95 Director
from the results i've see it its not really worth the swap.
Old Apr 28, 2005 | 12:53 PM
black01_WS6's Avatar
what i have read its not worth it unless you are using a power adder. if you want to put a power adder on later I would go with the 1 7/8.
