Air Pump Hose Routing
Rob
(which was different from the 98, 99'swhen I bought my first lid in 2000). The AIR system drew its air from the stock silencer, plumbed down the fender to the pump and then to the exhaust manifolds. When you remove that silencer on the 2000, you had to put a little breather filter on the tube so it could pick up fresh air. The 93 had the same kind of setup, the inlet tube was plumbed into the cold air.
Rob
Rob
