Water pump, which is inlet and which is outlet?
Old May 2, 2005 | 05:37 AM
GTS346's Avatar
Default Water pump, which is inlet and which is outlet?
On the LS1 water pumps, is the bottom opening with the thermostat the water inlet (cold coolant goes thru 1st) and the top opening of the water pump gets the outlet (warm coolant going to top of radiator)?
Eg. Can you run regular SBC radiators on the LS1 this way assuming correct hoses are in place.
