High Idle (Throttle Body)
Old May 4, 2005 | 06:10 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Thumbs up
Originally Posted by TransAm52804
Not to hijack, but is it a pain to mess with the idle screw? My car idles at 12-1400 rpms half the time, whereas sometimes it'll idle lower than 1000. I REALLY need to fix this because IMO it's a waste of gas plus it sounds like **** idling that high and it's been driving me nuts for a long time.
Are you getting any codes? Maybe a high idle speed code? As said above, it may be your IAC motor (assuming your throttle body is stock, and your motor is still stock). I was having a similar issue to yours with my '98, intermittent high idle with an otherwise stock car, and no other effect to driveability other than idle speed. The only DTC I ever got was just a high idle speed code one time.
I was able to hear the IAC motor grinding when I'd turn the key off. It had to be real quiet around the car and the hood needed to be up for me to hear it. No need to start the car, just park in the garage or someplace real quiet (maybe at night) and turn the key to the 'run' position, wait a second, then turn it off. Have the hood popped and stand outside the driver's door (just operate the key through the open window). Listen for a grinding, or 'rocks in a can' sound coming from the TB right after you turn the key off. If you hear that, I'd try replacing the IAC motor. All my issues (both high idle and grinding noise) went away with the new IAC.
The IAC motor is on the left (driver's) upper side of the throttle body. On that left side you will find two items attched to the throttle body (IAC motor and Throttle Position Sensor). The upper attachment is the IAC motor, it's directly above the TPS. The IAC motor has one eletrical connection (plugs in) and is held in with two torx bits. It's very easy to remove/replace, but after you loosen and remove the torx bits, don't worry if you have to pull on the unit a little to get it out, there is a rubber o-ring that seals it into place that may stick a little.
I think a new IAC is about $100 from the dealers. Maybe closer to $150.
Hope that helps.
Old May 4, 2005 | 08:11 PM
LS1BlackBird99's Avatar
Originally Posted by Bo White
Did the stock blade make it idle right? Just send that stocker back to me so I can have a replacement
Sure did fix it.
Old May 4, 2005 | 08:31 PM
Bo White's Avatar
Great! I knew it would. Did ya get your moneys worth?
Old May 4, 2005 | 08:32 PM
From you? Definitely!
