X, Y-Pipe Question
Old May 3, 2005 | 03:20 PM
lnuxhakr's Avatar
Default X, Y-Pipe Question
Please excuse my lack of knowledge on this subject but I need opinions and suggestions from anyone interested. I am getting ready to order Pacesetter LTs, non-emission style and my question is as follows:
Is there any reason that I cannot just have headers, an x-pipe (bye bye cats!) and turndowns before the rear axle. I know this is similar to true duals but Im not going to be running any mufflers at all..just open headers and an x-pipe. I plan on deleting the AIR, EGR amd CATS after the install. Is there any issue that I should be aware of in the programming, SES light problems, O2 sensor issues or anything else. I am not worried about the loudness or emission.
Thanks in advance,
Ben
Old May 3, 2005 | 03:43 PM
psykoTA's Avatar
Thanks in advance,
Ben
Youll need to have a tune to delete the EGR and AIR codes, and well as the rear O2 sensor code, since your ditching the cats.
And that would be insanely loud for the street
GuitsBoy's Avatar
If you can handle the rediculous volume, drone, and raspiness of the setup, youre okay in theory. Youll still need to run either rear o2 sims or just get the rear o2 sensors tuned out.
Old May 3, 2005 | 03:54 PM
psykoTA's Avatar
I really dont think he gonna get raspiness with this. He will probably get the back firing type sound when he lets off the throttle after a hard run. But no rasp.
Old May 3, 2005 | 05:17 PM
Camaro99SS's Avatar
No reason at all. It'll be a true dual exhaust but just without mufflers. Just get an X pipe kit like what Summit and Jegs has or buy an X pipe and have a shop run pipes back from the headers to the X and a little after and put dumps on.
Jason
Old May 3, 2005 | 05:27 PM
lnuxhakr's Avatar
Jason
For some reason I thought that the x-pipe would bolt up directly to the headers and Id just put turndowns on the other end (exit) of the x-pipe...is this not correct?
Thanks,
Ben
