Altenator bolt solution for short belt
Old May 7, 2005 | 01:19 PM
redmist's Avatar
Default Altenator bolt solution for short belt
On my BMW 557i conversion I used a 52.5 inch Dayco belt (results in tensioner being exactly in the middle of the range with stock pulleys) and deleted the power steering and idler pulley. I took the bottom altenator bolt cut it in the middle and added 1.5 inches of bolt shaft from another bolt. I then welded a grade 8 washer 1 and 1/8ths inches from the bottom of the head applied some blue loctite and re-inserted the bolt, Now only the bolt shaft goes under the belt and I have a solid altenator.
Old May 7, 2005 | 10:34 PM
felton316's Avatar
Damn fine creative thinking! I would try doing this myself, if I wasn't such a pansy and had to keep my power steering. I did the whole no power steering thing in an older mustang, and I swore I would never put my self through that again (or no power brakes).
Old May 7, 2005 | 11:00 PM
DanZ28's Avatar
Great idea! I only do the short belt at the track, but at least I wouldn't have to mess with removing that bolt using your idea, thanks!
Dan
