'00 Catch Can Mounting
Old May 10, 2005 | 09:26 AM
Bens 2000WS6's Avatar
Question '00 Catch Can Mounting
I have a '00 Trans Am with the EGR still installed. I am thinking of getting a catch can for the car seeing as how I keep hearing about the oil consumption issues. I was wondering, I read all over the place about how people have installed these that dont have the EGR, but what I am wanting to know is there anyone out there that has installed a Catch Can from AMW and if so do you have any pictures of how they are installed?
Old May 10, 2005 | 11:44 AM
cyphur's Avatar
remove the EGR, easy as that.
you can hook them up anywhere in the engine, just have to make sure the hose reaches. do a search and you'll find some pics of how other people have done it.
Old May 10, 2005 | 02:21 PM
SSpeedracer's Avatar
I've got a '00 camaro and kept the EGR intact. Can is mounted to passenger side fog light bracket with a hose clamp and hoses are routed through a hole in front of the battery. To drain I loosen the access flap under the fender 2 10mm bolts and open petcock valve.
This was easy to perform. I really need to take pictures.
