MAF Ends? Are they worth it?
Old May 13, 2005 | 10:09 AM
'72vettebaby's Avatar
Default MAF Ends? Are they worth it?
There's been so much negative feedback about the aftermarket mass air flow sensors not really helping much and even hurting your engines performance I don't think I'll be buying any one of them. But what about the MAF ends? Do they work? Are they worth it?
Old May 13, 2005 | 10:17 AM
99blancoSS's Avatar
For the price of them I woldnt buy them, but you can de-screen and port your own. Some have had trouble from doing it, others havent. I did it and havent had any trouble.
Old May 13, 2005 | 10:37 AM
777's Avatar
777
my advice don't mess with the maf
Old May 13, 2005 | 11:13 AM
99blancoSS's Avatar
Lots of people have brought headaches on themselves by messing with their MAF. Look at it. There are 3 tiny wires with sensors on them. The ends come off the MAF and thats how you port them. Take care in dis-assembly and re-assembly and you shouldnt have any trouble. But good advice is to not mess with it. I havent dynoed since I did miine so I cant give you any results but it falls in the category of every little bit helps. You could alwasy do what I did too and thats buy a used maf and experiment with it. I have the MAF right here and the ends are on my car. My ends are on the shelf untouched.
Old May 13, 2005 | 11:41 PM
JonB's Avatar
I've also wondered about these. I think if i ever do get them they will be used or a great deal from a sponser every once and awhile i see them for like $45 which ain't bad i guess. I would't mess with my stock ends unless i have a spare cause if you mess up and it runs like **** you have nothing to go back to
Old May 14, 2005 | 12:33 PM
Redneck Z's Avatar
MAF ends are a bad idea. If you want your car to run leaner, do it the right way and get a tune so it runs right. MAF ends just trick your car into running leaner.
