New cats/headers and clearance
Is this true or how have you dealt with it?
Any input would be much appreciated, hope this was clear. If not feel free to ask questions.
Clearance shouldn't be a problem with new LT's/Y-pipe. You gotta be careful of course. You will lose some clearance, but it's not like you had a ton to start with.
Hope this helps
I have the Eibach Pro kit on my 01, it's lowered aprox 1.25".
Here is my oem Ypipe:
http://nick.vettextc.net/Ypipe/OEMYclr.jpg
Here is ground clearance with long tube headers and a 3" ORY:
http://nick.vettextc.net/Ypipe/TSPORYclr.jpg
I went from 3.25" down to 2.5", so I lost 3/4" going from the oem oval to a 3" round. The common problem people have with 3" aftermarket Y pipes is with clearance between the pipe and under the car causing banging which in turn can result in false knock.
http://nick.vettextc.net/Ypipe/TSPy004.jpg
Alot of guys here have come up with ways to help fix that so don't let it scare you away from putting headers on your car.
