header install question
Old May 20, 2005 | 09:08 PM
redtransam02's Avatar
Question header install question
I have got the first two header bolts out on the passenger side, how do i get to the back 4 i have tried everything but i cant reach them cause of the a/c system, any help would be appreciated please
Old May 20, 2005 | 09:18 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Did you take off the coil packs?
Old May 20, 2005 | 09:20 PM
not yet i havent, if the ac box wasnt in the way i could get them out so takin off the coilpacks will help
Old May 20, 2005 | 09:23 PM
NviouSS's Avatar
take the coil packs and spark plug connectors. if you don't already have a 10mm ratchet wrench, i suggest investing in one. it helps a ton for the back bolts.
Old May 20, 2005 | 09:24 PM
yea i have been tryin to find one the only one i found was bout 4inchs long which u might as well be usin ur hands lol on that but im still searching, i will try the coilpacks an see if that helps appreciate the info guys
Old May 20, 2005 | 09:35 PM
JBIRD02's Avatar
Theres gonna be alot of stuff in your way, just stick your arms in there and start wrenchin, your hands are gonna get cut up anyways, might as well get started! I didnt remove my coil packs and I had no problem getting the bolts off, however he's right, removing the coil packs will make it easier. Just find the right combination of socket extensions for each bolt and its a piece of cake.
BTW, a gear wrench will be your best friend on the last bolt on the #8 cyl. which you will probably have to get from underneath the car
Old May 21, 2005 | 01:07 PM
USMARINE1108's Avatar
I got that passanger side rear manifold/header bolt from under the car. I think it's A LOT easier. Or get someone with smaller hands to help you out. Never hurts go let someone else give it a shot.
Old May 21, 2005 | 02:08 PM
SiRgReg23's Avatar
Temple, TX Resident
dude lay on the car and stretch ull find the best positions to get at all the bolts ... most of them will take many turns to get out
 Michael S. Palmer
Old May 21, 2005 | 05:07 PM
JarredWS6's Avatar
Im with usmarine1108 on the rear bolt. Its quick and easy from under the car.
Old May 22, 2005 | 12:14 AM
oh yea it was a pain in the a$$ but i got it out finally, i appreciate all ur help guys, got the install finished tonight an man its well worth it, the headers tuck up really nice
