Question about Ported TBs
Old May 22, 2005 | 01:23 PM
PopaPork's Avatar
Default Question about Ported TBs
I just installed a ported TB on my car, that I bought from an guy on here. Everything is hooked up and I"m throwing no codes but it seems that when I take my car out of gear and let it coast to a stop, like a read light, the RPMs stay higher then they use to. Is this normal or did the porting go too far?
Old May 22, 2005 | 02:16 PM
cyphur's Avatar
is the blade drilled for a larger cam? and is everything after the MAF sealed up well?
Old May 22, 2005 | 04:26 PM
8-Pack's Avatar
Mine did the same thing. Its normal and it tends to fade over time, but it wouldnt hurt to check for the things cyphur_traq suggested.
Old May 22, 2005 | 04:29 PM
PopaPork's Avatar
Everything seems to be sealed up well after the MAF, I will check agian though, and I don't think the blade is drilled for a larger cam, but I will check that too. Thanks
Old May 22, 2005 | 04:51 PM
Tally TransAm's Avatar
turn down the set screw to close the blade a little more. its probably open a hair to much and is throwing the iac outta whack
Old May 22, 2005 | 07:29 PM
PopaPork's Avatar
Just to clarify...Turning it down is making less of the screw stick out correct?
I just noticed something else with it. When I come to a stop, a dead stop, it takes maybe a second or two for the idle to drop where it should be normoally. Still the screw? Someone said that I would have to have the computer relearn the "0" for the TPS. Is this the case?
