Catch can ? and some install pics
Old Jun 4, 2005 | 06:12 PM
shep28's Avatar
I had that vacum leak like sound when I forst put mine on. I filled the catchcan with a little bit of oil and the sound went away. My drain plug at the bottom was also tight.
I used teflon tape so I could turn the plastic fitting to the dirsction I wanted the hoses to point.
Screwing the bracket to the catchcan was difficult. The screw heads are inside the circular bracket.
Old Jun 4, 2005 | 06:43 PM
jj_z28's Avatar
So w/ all this said, the pics I posted in the 1st post are correct. Right?
jj_z28's Avatar
Do alot of people need to leave a little oil in the bottom at all times?
Old Jun 5, 2005 | 10:32 AM
WILWAXU's Avatar
Looking at the pictures.. it looks like you have taken the PCV out. IMO, it should stay in. Here's what a 99+ PCV system should look like. http://www.ls1howto.com/content/info...kpcvsystem.jpg
The PCV valve is located in front of the intake on the passengers side, held in place by a ground strap to the coolant tube. Yours looks to be missing...
I ran my can straight off the stock setup. The only thing removed from the stock PCV system was the small elbow that attached to the intake neck.
I ran the top hose of the can coming off the tip of the PCV and the side hose come off the intake neck.
Old Jun 5, 2005 | 10:37 AM
WILWAXU's Avatar
AMW install instructions:
http://www.accmachtech.com/PCVCatchC...structions.pdf
