Belt For water pump only
Old May 27, 2005 | 01:01 PM
AnoxieGTO's Avatar
Default Belt For water pump only
Do they make a belt that goes from the crank to the water pump and tensioner only? If so where can I get it? And any gains? This is for a 04 GTO not a f body...
Old May 28, 2005 | 12:10 AM
Ferocity02's Avatar
Use a piece of string and route it where you want the belt to go. Measure the length or take it to an autoparts place and see what they have. It will get you in the ball park and you will have some tension to play with. For my Procharger, the difference between the belt fitting and not fitting was only 5mm.
Old May 29, 2005 | 08:11 AM
BigAl1's Avatar
What about the direction of the water pump pulley? If the belt goes over the top of the pulley, it spins the same direction as the crank. If it goes under the pulley, it spins opposite the crank.
Old Jun 1, 2005 | 10:38 AM
AnoxieGTO's Avatar
which way do I want it to turn or does it matter?
Old Jun 1, 2005 | 05:00 PM
Ferocity02's Avatar
Whichever way it turns from the factory is the way you want it to turn. Yes, it does matter.
