quieting exhaust
) I suppose you could attach some bullets right after the Sweet Thunders, but I doubt you'd need to do that. good luck as I bet this is a royal PITA, but I think it's possible to quiet down TD's.
Jason
Spoken like a true butthead
Invest in the Sweet Thunder chambered mufflers. It'll quiet the TDs down enough and still sound badass. Trending Topics
But before doing anything, I suggest going to each of the neighbors who have complained and discussing it with them. Be courteos about it. If you're nice to them and maybe offer to do a few things for them once and awhile such as lending them the use of a lawn mower if theirs is broke, I bet they'll loosen up with you about your car.
Jason
I started with regular TSP duals with bullets; sound great but too loud.
Then had the 3" tailpipes made up; way quieter in the cabin, incredibly loud behind the car, sounded like **** anytime EXCEPT at WOT, waay loud.
Then had the bullets replaced with the twisters; quieted things down cosiderably, but got really bad rasp throughout the entire rpm band.
Then installed the resonated tips; quieted things down even more, took out the rasp, sounds sweet AND quiet. The trick is to get tips made for pipes larger than you are actually using, so the inside dosen't neck down smaller than your exhaust. I love this setup. I live in a quiet residential neighborhood, I leave at 5AM, and the neighbors respect the fact that I've done what I can to quiet her down.
Oh and when I want to, it takes 5 minutes to unflange the tailpipes and remove them, dumping the exhaust after the twisters, and it sounds naasty all over again!
