Where are the front 02s
Old May 28, 2005 | 01:15 PM
Z-286speed's Avatar
Default Car problems with the 02s?
My buddie and I did the header install, and he unplugged the front 02s while i was doing something else, and can not find where they plug up. Any pictures or close to where it is suppose to go would be awesome!
Old May 28, 2005 | 01:26 PM
SiL3NtXWS6's Avatar
one is behind the alternator, the other is right behind the passenger motor mount
Old May 28, 2005 | 09:40 PM
Z28LS1camaroguy's Avatar
yeah what he said, they should be easy to find they are holes in the pipes with a bolt thing welded on.
Old May 28, 2005 | 11:26 PM
Z-286speed's Avatar
Ok, I hooked up the 02 sensors. Was running fine down the street, but still was throwing codes. So, i thought some time would help. Drove around, gave it some gas and what not and the car will not idle now. It was set at 900 rpms, but now it is at 200-400 range. Would this be from the 02s or what? I drove from lubbock down to houston without any of these 02s and did fine, break in process. And was also throwing flames idleing so low. Please help out.
Old May 29, 2005 | 11:28 PM
could be the computer has to relearn so to speak, otherwise you will have to have the gm dealership diagnostics scan it to see what the problem reallly is.
