Hatch won't open
Old Jun 3, 2005 | 07:19 PM
theblur98ss's Avatar
Default Hatch won't open
Not sure if this is the right place or not but I can't get my hatch open. Nothing happens when I push the clicker or the button under the dash. The key never has worked. Put it in and it won't turn. Any ideas? Is there a module I could look for? The power locks work with the fob.
Old Jun 3, 2005 | 10:35 PM
WS6FirebirdTA00's Avatar
check fuses, pull off that panel where the button is and look at the connection and make sure its good still. could be a bad switch?
Old Jun 4, 2005 | 03:25 AM
Z-286speed's Avatar
Rear hatches go out, might want to look into a new hatch assembly(after checking fuses).
Old Jun 4, 2005 | 12:22 PM
bboyferal's Avatar
http://www.installuniversity.com/ins...elease_fix.htm
Try this stuff before you give up...
Old Jun 4, 2005 | 12:36 PM
Red99TA's Avatar
I did this little spring fix on mine and now it unlocks every time. Before I would have to hit unlock at least twice to get it to unlatch. Now I just need some struts so it opens on it's own.
Old Jun 4, 2005 | 02:26 PM
yeah that spring this is awesome, now it is like the hatch will blow off the car when u unlock it lol
