For Those W/ Catch Cans--?
Old Jun 3, 2005 | 09:21 PM
BoneSS's Avatar
Default For Those W/ Catch Cans--?
What parts of the PCV system does it replace? I am changing from a 98 system to a 99+ system. I am going to go with the AMW Catch Can, and need to know what other parts I need to buy, and those part numbers. Thanks.
Old Jun 3, 2005 | 09:51 PM
Z28Venom's Avatar
You don't actually replace anything. You just put it inline with your current PCV system. It goes between the PCV valve and the input into the intake manifold.
Old Jun 3, 2005 | 10:03 PM
LawmanSS's Avatar
It supplements the factory system...
Old Jun 3, 2005 | 10:06 PM
BoneSS's Avatar
LawmanSS--you gave me the part numbers:
222 - 12562580
241 - incl w/222
273 - 10198949
280 - 12556454
while onyxxterme gave me the part numbers
the complete hose with PCV valve is gm part number 12573108
also needed is the grommet for the driver side valvecover, # 10198949
which one is correct?
Old Jun 5, 2005 | 03:42 AM
BoneSS's Avatar
Did you all buy the bracket?
Old Jun 5, 2005 | 04:32 AM
Blacker's Avatar
I did
Old Jun 5, 2005 | 10:24 AM
LawmanSS's Avatar
The #'s I gave you came from my GM Parts manual...it's possible that the number I gave you has changed to the one onyx gave you...the manual lists 12562580 as the 99-02 complete hose w/valve...it would probably be best to check with a dealer to confirm the correct number...
