PCV Problems... need part name
Old Jun 4, 2005 | 12:17 PM
Cerebrex's Avatar
Default PCV Problems... need part name
The hose that goes in the rear of my driver's side valve cover... What is that called. It is no longer sealing with the port on the valve cover because of removing it and putting it back on so much. Is that the PCV valve, and if not, what is it called? I have been burning oil lately, surging at idle, and have a hissing under the hood lately because of this, so I would love to correct it ASAP. Any help would be appreciated!
Old Jun 4, 2005 | 12:36 PM
Grimes's Avatar
The part you are mentioning is listed as "PIPE, PCV VLV" for 99-02 ls1 part number 12562580
I tried searching @ gmparts direct and autozone, but nada for the part number. Are you sure you just cant use some rtv or a hose clamp to get it tightened down again?
Old Jun 4, 2005 | 12:49 PM
Cerebrex's Avatar
Hose clamp what? It isn't sealing where the metal piece on the end of the hose goes into that robber gromet thing on the valve cover. I tried RTV and it just isn't working at all.
