H-pipe install ???
Old Jun 6, 2005 | 02:49 PM
chpmnsws6's Avatar
Default H-pipe install ???
i was told by a BIGTIME mustang person that with an H-pipe you have to be so many inches away form the collector (he said over 12 inches). is this true?
i want to do a true dual setup and i think if i can put the merge pipe close to the collector i can fit my exhaust (spohn tunnel mounted torque arm)
Old Jun 6, 2005 | 08:33 PM
99FormulaM6's Avatar
im pretty sure hes partially correct. you cant just mount the h pipe right after the headers or anything, but i dont recall exactly how far
Old Jun 6, 2005 | 08:57 PM
SeeYaSucker's Avatar
The only way to find the optimal point for the crossover is to get some black LOW temp cheap paint and lightly spray the pipes about a foot back from the headers to where the mufflers will go, not the whole pipe just a straight line, then crank the car and drive a while, and where the paint is gone the most, you will be able to tell, that is the optimum point, sometimes the f- bodys suspension wont allow it but just get it close.
