Need Help Fast: LS6 Intake Install Problem (people knowledgable with HPTuners inside)
It also showed that the "long term" fuel things (I'm a technical newbie) were maxed out, and the "short term" ones were going up until maximum to compensate. We checked around and all hoses and electrical plugs, injectors, everything is plugged in as far as we could tell (hard to tell with the hoses in the back of the intake though). All fuses were fine too.
Has anyone ran into this problem? I'm so lost, as are just about everyone else who've tried to help resolve this problem. And the thing is, I'm in a hurry because in a week and a half, I leave for Ohio for Thunder in the North.
Anyone, any help would be incredibly appreciated, especially those who know HPTuners in-depth.
Edit: Also FWIW, the intake is used (BAM-BAM's old setup). It had only 5K miles on it before. I didn't check the intake for o-rings, but I assume it had/has them anyways since all BAM-BAM did was take it off, sell it to me, etc. The o-rings weren't tampered with basically, so I imagine they're still on there. Hopefully that helps to narrow the possible problems down a bit.
Basically, what would cause the injectors to show ZERO pulse on the graphs? And would that cause the car to idle/run like it does?
What would removing those clips do, BTW?
A few of you were right: there was not a SINGLE manifold gasket out of all eight!!!!! How it slipped past of the first time, I dunno. I didn't know too much about all of it so it didn't cross my mind. But tonight, when turning the manifold over to check for the gaskets, I was first pissed off but then SOOOOOOOOO relieved to see not a single gasket, because that meant I found the problem and know it will easily be solved!
I'm gonna get the new gaskets tomorrow and we're gonna re-install the LS6 on Sunday night. God I'm so freakin' happy right now. I've been in the "f*ck everything" state of mind the past week because I was so lost with this.
Now I can get her ready for Thunder in the North next weekend.
Also FWIW, you can see my current best with just lid and catback: 13.1@108.4... Would the LS6 enable me to hit 110 on a good night? Of course I'd love to see 12.9's too, but would it give me about another 2 m.p.h.?
I actually just retuned my idle and part throttle today and finally set my pinion angle correctly on my car!!! Im loving her again
Intake gaskets aren't cheap. I got mine from Thunder for around $65 for the set.
I haven't checked dealer prices.
