need some help
Old Jun 10, 2005 | 05:17 PM
99nbmws6's Avatar
Default need some help
well i had some sqeaking comming from my car, after doing some research on the board i found out that it was a pulley problem or a belt problem, well i changed both of them amd it still makes the noise, its not as loud as it was but it still there, it is really noticable when i shut the car off.
i have a warranty with the car but i dont want to spend the $100 dectuible if its not going to cost that much. what could be wrong with it.
thanks
steve
Old Jun 11, 2005 | 06:22 AM
Dustin Butts's Avatar
Need more info. Describe squeaking sound....where is the noise coming from..etc
Old Jun 11, 2005 | 07:47 AM
conan's Avatar
Try takeing the A/C belt off and running the car that will isolate your problem. My compressor was squeeking on mine. I solved that problem by taking the all of the A/C unit out of the car. If that doesn't change anything take off you idler pullies and check the bearings.
Old Jun 11, 2005 | 11:13 AM
99nbmws6's Avatar
thanks for all the info will try some stuff today.
Old Jun 11, 2005 | 11:43 AM
Uno99's Avatar
Could be your cooling fans. I know on my beater when i turn it off the fans squeak just before the come to a stop.
