Having issues with ASP pulley and gates A/C belt.
Old Jun 10, 2005 | 10:00 PM
Captain InsaneO's Avatar
Angry Having issues with ASP pulley and gates A/C belt.
I did some research and found that I was to use a K040378 Gates belt for the A/C. The belt will not fit. Its way too small. The belt that came off was a Gates K040410 and its waaay too big.
This belt is too easy to install for it to be a mistake of mine.
I measured the belts and theres a 1.5" difference in the two. How can the K040378 belt not fit if thats what everyone is using?
What am I missing here???
Old Jun 10, 2005 | 10:42 PM
WILWAXU's Avatar
How are you routing it?
Old Jun 10, 2005 | 10:57 PM
Just like the diagram shows. I start with the crank then run it under the smaller pulley running across the tensioner and it goes half way on the A/C..
Old Jun 10, 2005 | 11:31 PM
Ferocity02's Avatar
You are pulling down on the tensioner right?
K040410 = 41"
K040378 = 37.8"
Maybe get a belt right in the middle, like a K040390?
WILWAXU's Avatar
The belt goes between the two tensioners,
The tensioners come together to make the belt tight.
Old Jun 10, 2005 | 11:33 PM
Right.. I know, thanks tho.
Old Jun 10, 2005 | 11:34 PM
K040410 = 41"
K040378 = 37.8"
yes I am. i'll try again tomorrow, and if it won't work I'll get one in between.
thanks!
Old Jun 11, 2005 | 12:01 AM
Ferocity02's Avatar
Also sometimes the wrong belt gets put into the package. I'd take it back and see how long it really is.
Old Jun 11, 2005 | 12:20 AM
Beast96Z's Avatar
When I was searching for belt part numbers on here, the ones that were supposed to be right were no were close. The boxes I have here in front of me show the A/C belt to be 37.8 and the Large belt to be 70". These are for a 25% underdrive.
