LS6 Intake
Old Jun 12, 2005 | 09:03 PM
FormulaFire's Avatar
Default LS6 Intake
If I buy an Ls6 intake manifold what else will I need to install it on my 99 Trans Am Ws6?
Old Jun 12, 2005 | 09:44 PM
sandking's Avatar
You will need the cross over tube and two coolant block off's
Old Jun 13, 2005 | 10:46 AM
Kirby's Avatar
and how would you get those as well as where?
Old Jun 13, 2005 | 11:13 AM
Lithium's Avatar
SSU's Drunk Typing Whore
I got mine from the local dealership, it costed me 50 bucks for everything.
Here are the part numbers for them both:
(2)Plugs - 12570678
(1)Pipe - 12581213
Old Jun 13, 2005 | 11:31 AM
blkZ28spt's Avatar
I belive it's SLP that sells one you don't need those for....maybe....i'm forgetfull....
Old Jun 13, 2005 | 11:34 AM
Lithium's Avatar
Yeah I forgot about that SLP sells a kit as well.
Old Jun 13, 2005 | 11:51 AM
DONAIMIAN's Avatar
Dont forget to take it to s shop or a buddy with edit or hptuners todelete that EGR.
DONAIMIAN's Avatar
block off plates for the EGR too.
Old Jun 13, 2005 | 02:07 PM
Kirby's Avatar
You won't need a block off plate if you get a true LS6 intake.
Old Jun 13, 2005 | 03:10 PM
777's Avatar
777
Unless you get the one that has the egr fitting like the SLP one.
Old Jun 13, 2005 | 08:00 PM
Spurtle's Avatar
Yes you will .. He said a plate not a plug. The Plate covers the large hole in your manifold or header. The EGR has 2 connections to the engine, the Exhaust and the Intake.
Old Jun 13, 2005 | 08:30 PM
Kirby's Avatar
Guess thats ur problem and not mine. I have race only headers so I might as well get rid of the EGR and AIR system since there is no place for them to hook up. I just can't right now because of the codes. Running with those codes won't cause my car to idle or run weird will it?
Old Jun 14, 2005 | 10:32 AM
Bryan @ Speed Inc.'s Avatar
no i don't think not having the e.g.r. or air injection will change how the car runs. it's just the o2's that will change it if you don't have a tune, or simulators on a non catted y-pipe. but even that it will only run slightly rich. (i believe).
Old Jun 14, 2005 | 04:36 PM
your car will run perfectly fine without egr and air. removing the egr will throw a code and the Service Engine Soon light will stay lit, but don't worry at all. Nothing bad will happen. You can get programs to make the light go off by tune.
Old Jun 14, 2005 | 08:02 PM
Y2K SS's Avatar
You'll only get the SES. Won't hurt jack. You will get more airflow and your car will probably run a lil on the lean side but it'll be fine till you can get tuned.
Old Jun 15, 2005 | 10:25 AM
VTC_WS6's Avatar
While on the topic of LS6's, what kind of gains are people seeing with bolt-on LS1's when swapping to an LS6 intake?
I've got a '00 WS6 with a lid, LTs, ORY and catback and I was just curious about what to expect from the LS6 I have laying in my office..
Old Jun 15, 2005 | 12:07 PM
Y2K SS's Avatar
depends how modded your car is. Stock cars have been seeing like 12-15 hp gains and heavily modded cars were seeing up to 25hp gains.
Old Jun 15, 2005 | 12:46 PM
777's Avatar
777
I'll agree with ^
Old Jun 15, 2005 | 05:15 PM
Kirby's Avatar
rwhp I'm guessing??
