ignition?
Old Jun 13, 2005 | 12:42 PM
ozzykicks2002's Avatar
Default ignition?
I did not know where to post this. so here I go. .
In the morning when I start my car, I usally have to turn the ignition about 2 or 3 times before it starts. Now it does not even turn over, it make a click sound and thats about. Then on the 3 try it will turn over and start. Im thinking that its a bad battery with a dead cell maybe. Cause in the morning is when its had the most rest I.E. It has not been starting for about 8 hours. bit if that is the case then then it should not start it all. Any ideas?
Old Jun 13, 2005 | 02:33 PM
bump. . .
Old Jun 13, 2005 | 03:02 PM
ThirdGenLS1's Avatar
if your hearing a click sound it prolly your battery, just go grab a new one and see what happens, if not then i would move on to the starter. You can bring your battery in to like autozone and they will do a test on it it to see if its bad or not.
Justin
Old Jun 13, 2005 | 03:21 PM
well if I bring it to a store wont it appear to be full and good sence the altanator will be charging it?
Old Jun 13, 2005 | 03:28 PM
2001NBMZ28's Avatar
Sounds like the battery has died - if you still have the stock AC Delco check the positive post for any leaking, and see if the eye is still green. Like Justin said Autozone will test it for free.
Old Jun 13, 2005 | 03:31 PM
2001NBMZ28's Avatar
They'll do both a voltage and "load" test.
Old Jun 13, 2005 | 10:25 PM
Cool thank you
