Problem after i installed my FAST 90 mm
Old Jun 18, 2005 | 12:14 AM
Okie02's Avatar
Default Problem after i installed my FAST 90 mm
Ok i finally got my fast 90 intake installed along with a nick williams TB..this is my problem. my throttle cable is to damn tight...is there any way to adjust it? there are two notches on the TB to put the cable in one is to tight and the other is way to loose...its barely to tight so is there anyway to adjust it? also when i was installing my TB i noticed they didnt send a bolt that is long enough to go through the top hole...does anyone know the specs on the bolt i need so i can pick one up? thanks!
Old Jun 18, 2005 | 12:31 AM
LawmanSS's Avatar
Top bolt specs are M6 x 60mm.
Old Jun 18, 2005 | 03:11 PM
Dustin Butts's Avatar
I have the FAST TB but I have two cable holes also. I used the top one. It was too tight originally. I had to reem it out a little with a drill bit. You don't need the drill, just the bit. The aluminum is soft.
