True Duals on 1998 T/A
The best part of this system is it is much quieter than using bullet mufflers. You can actually sit in the car, windows up, and have a normal conversation, until you nail it. At idle, it is very deep and authoritive, but still not blowing your ears off. I did have to modify the rear seat pans somewhat, but nobody ever sits back there due to a roll bar in the car. If you look real hard, you can see where several inches of seat pan was removed and new pans welded in. This is where the mufflers tuck into for the added ground clearance.
