Slp Underdrive Pulley
Old Jun 25, 2005 | 05:17 AM
bernard shortt's Avatar
Default Slp Underdrive Pulley
How Does The Slp Under Drive Pulley Do,will I Need To Go To A Slp Radiator To Keep My Slp Stroker From Over Heating With A Stock Waterpump?
Old Jun 25, 2005 | 05:53 AM
GuitsBoy's Avatar
As with most things SLP, your money could be better spent elsewhere. The stock LS1 cooling system is pretty stout, so you probably wont need a bigger radiator, although it couldnt hurt.
Also, unless your typing the title of a book, its not necessary to capitolize the first letter of ever word. Im not trying to give you an english lesson, its just that it makes the sentence harder to read quickly.
Old Jun 25, 2005 | 06:00 AM
I,m an er nurse and i need no english lessons ,our system here only uses caps.
Old Jun 25, 2005 | 06:03 AM
GuitsBoy's Avatar
I only brought it up because many people will skip right over posts using all caps and first caps and not bother reading. Didnt mean it as an insult.
Old Jun 25, 2005 | 12:12 PM
blkZ28spt's Avatar
Enough SLP products there?
You should be fine. I have the SLP UD pulley and Imy temps when I get stuck in traffic have been hotter, but it's also hotter right now than it had been for over a year, so I can't really compare since I had a lot fewer mods 2+ years ago the last time it was this hot.
Old Jun 26, 2005 | 04:27 AM
Default slp underdrive pulley
can you tell any difference in power?
Old Jun 26, 2005 | 11:39 AM
blkZ28spt's Avatar
The pulley was done at the time time as an LS6 intake manifold and a converter restall.
