install help - in a rush
Old Jun 27, 2005 | 01:58 PM
99FormulaM6's Avatar
Exclamation install help - in a rush
ok, i have oil temp and water temp gauges i need to install. for the water temp, im told to just unscrew the plug thats above the #8 cylinder on the pass. head, and then replace it with the sender provided with the gauge. correct? i realize im going to loose coolant, so just keep some handy i guess.
for the oil temp...now i get lost. is it plug and play? ive heard i can put the sender above the oil filter. but how? i know someone else has done it here, so someone has to know how to do it. i really dont wanna pay someone to do this, as its kinda trivial.
Old Jun 27, 2005 | 02:44 PM
WS6FirebirdTA00's Avatar
you will need a new sender unless they did somethign in the kit, i had to order one that fit, or you can buy one
Old Jun 27, 2005 | 08:24 PM
do you know what sender i need? or what i need to make the one they sent work? i wanna get everything together to make it as quick as possible.
Old Jun 27, 2005 | 08:37 PM
rufretic's Avatar
My autometer water temp sensor needed an adapter to fit where your talking about. They have them at auto barn. By the way, its a bitch to get at it. I got it from under the car.
I can't help you with the oil temp, sorry.
Old Jun 27, 2005 | 08:49 PM
do you know what adaptor....?
as for the oil temp...
someone has to know, i know im not the first person to do this
Old Jun 27, 2005 | 08:53 PM
you can call autometer and buy an adaptor for the water temp
im getting an oil temp, have to tap a hole in something near the oil filter, havent looked at it yet but we will see. id like more info on this as well, there is a site somewhere about it but i cant find it now
Old Jun 27, 2005 | 09:02 PM
i know a site, but the guy got a special one made, or you can buy all kinds of adaptors and make it work. but its got to be simpler than that.
Old Jun 27, 2005 | 09:03 PM
http://www.xse.com/leres/ss/gaugepod.html
thats what i have found so far
 Michael S. Palmer
Old Jun 27, 2005 | 09:04 PM
rufretic's Avatar
http://www.autobarn.net/accessories1.html I want to say its one of those but I can't remember the size. Do a search on ls1tech and you should be able to find out which one you need. Thats how I found it at least. I bought a kit for like $14 that came with a few sizes and then I had to figure out which one it was. I can't find the kit now but I'm sure its there somewhere. Sorry I can't be more helpful but it will sure beat getting that bolt out and then finding out its the wrong size with all the coolant spilling on you. lol. Good luck.
Old Jun 27, 2005 | 09:08 PM
thats what i have printed up. but he says he made his own or something.
Old Jun 27, 2005 | 09:11 PM
ill see if i can find which one and see if i can pick it up local. i dont wanna wait for shipping
Old Jun 27, 2005 | 09:12 PM
what temp range do you have on your gauge?
Old Jun 27, 2005 | 09:20 PM
uhm, i dont remember. theyre out in the car. its a 2 1/16 CF one
Old Jun 27, 2005 | 09:23 PM
ook, well keep me updated if you find info on this, im gonna tap mine as of now i think, doesnt look too bad to do
Old Jun 27, 2005 | 09:27 PM
whats involved in tapping it? ive never done it....
Old Jun 28, 2005 | 05:08 AM
take that piece off, drill it out (dont know the correct drill size yet) and then just use a 1/8 in pipe tap to tap it
Old Jun 28, 2005 | 05:56 AM
what piece are you taking off? i have access to pretty much any tools i need...and help from alot of different people. so im sure i can do it.
Old Jun 28, 2005 | 06:12 AM
its right at or above the oil filter, i never took if off but if u look at the piece on that site you can see. maybe someone can chime in and let us knwo for sure. i know there are 2 bolts on it, and i just wonder if you just take those out andit comes off?
Old Jun 28, 2005 | 06:25 AM
oh, ok. im pretty sure thats all you have to do.
the plug in the passenger side head for the water temp sender, is the same size as a spark plug, right? so if i goto the parts store, i need to find an adaptor that, on the male end it the same size as a spark plug, and the female end will be the same size as the autometer sender
Old Jun 28, 2005 | 06:35 AM
not sure about the size but that seems close. you could always pull the plug out and go to the store with it, that will give the coolant time to drain some before you get in there so it wont get on you. but im not sure of the exact size, if you call autometer they will tell u
