March Pulleys, anyone have info
I agree with the above posting but remember that under drive pulleys are only good for adding a couple of HP but depending on the area of the country you live/drive in - it can be a pain in the backside. My 97 had a under drive pulley and overheated in heavy traffic/hot days. When you idle, the 12VDC is very low (almost into the red zone) and the fans are not moving as much air as they should. In the winter with the rear window defroster on at idle, low voltage etc. I finally remove it and can tell it is much better with the factory pulley.
Thanks
Bill
