SLP 85mm MAF
Old Jul 3, 2005 | 02:39 AM
RrCoX22's Avatar
Default SLP 85mm MAF
Does anyone know if the SLP MAF has the same size ends as the stock MAF. Since the stock MAF is 75mm and the SLP is 85mm does that include the ends of the MAF or just the sensor area. Just want to make sure it will fit the lid I have on along with my bellow. Thanks!
Old Jul 3, 2005 | 02:43 AM
Deamon2002's Avatar
I have it, it will. It is a little bit of a tight fit but if you spray a paper towel w/ WD-40 and apply a THIN coat to the outside of the MAF where it enters the lid and bellows, it will slip right on.
Old Jul 3, 2005 | 04:34 AM
SLP LS1's Avatar
Most people stick with stock MAF
Old Jul 3, 2005 | 12:45 PM
RrCoX22's Avatar
Ya well I descreened and ported mine like a dumbass and feel as if I lost some power just like all the others who's had problems doing this to their stock MAF.
Old Jul 3, 2005 | 12:50 PM
Corupted's Avatar
I have an 85mm MAF (not SLP though), but it fit fine. I've even heard of a prototype 90mm MAF that's been fitted into an LS1 (whoa)
Old Jul 3, 2005 | 01:06 PM
LSUxBlake's Avatar
The ends of the SLP 85mm maf aren't hard, they're flexible rubber that you clamp on, so you shouldnt have any problems fitting it.
